Photos What is wrong with my forge?
So using several of the tutorials on 2 brick forges I built one, per the pictures. However my Forge does not seem capable of getting hot enough. I tried widening the whole for my torch tip, which did not seem to do anything. I tried to introduce more oxygen with a blower. I have tried 14 oz and 16 oz tanks, but after the initial burst from the new tank the flame seems to insubstantial I have burned out 1 14 oz blue propane tank and to Ace brand 16 oz tanks all in the span of like 35 mins. What can I do to make this build work? Or do I need to start over.
Build list includes
Two Fire Bricks
A good coating of this refractory cement
and I have been using this Tip
Here are some relevant pictures. Any advice is greatly appreciated
2FjfLALHFKFXxxeSszQSyAg4iUcwB8A8C9fEnbsQgTq0MUuz773dMwU0S_CD8S08_9op-yvWszUEc7_KdyPDXgZKJ_EOJVRLSz315oLniHlgMgdSsuMjUKbHo9NXna4jF-x79n_quXdksl3GG-ugc94RW1KX1A7vqbhnhAhLARQClXZdqd2ZCBJhNFibrgk-_f0tKR-zmGSXiyFGDesq32coNazWjwEvy6quCMbbHFGsi3LA6ulxWFBakG2a5vAx453c99TIO1GIY3RaqnNf8g7Y6_9gSRT-d4brMVkGe5CD4Yp0_YmZEXbQu6z0UjMlF1Y2L4y1EUZV9vNTjW2T-hhSXWxgeqSsaNg1ER9_55CYtiztORNptWjyp1yM4VwH20ykFiaC9sJ4mn8s-T1rVV2Edy_kbj7506v_O6GtNRg0NTnoLOcMt8DMM4o372P7PeRXRiZ3gtzFmId5QuqaWZgPQXn5qb3BkRtvod1ZbGShvlfdE26SaSFHA1vaBCCnS0SIykHbq3kua9Dx7D9eRFmmn5tW62g7wk9GH8_R2XJm4JK1HJfMbJVy6tlLml7-jgr9cDK8bH9W8KAb_G2d2wgk4bAeErtIqa6s85Z7P7dCR-xlY1o64V78k0Apfyft0794nrR8-FoUaEWvdSqa0mmOIdNAdbRb7saztHfdLbtosJMDMjyjg1A=w1215-h911-no
WzjMUaBmOGivAYlWhIznOuowJ34TCCAo6Xl2FjQHWSfcH_I8rqtgffNsksgU5FrsUFylL2kZvX8-6k6T5mEutu6og9u1kODaw0BCyj_HqB4Zg9UFcD9TOGhXvlQFk3PnPnH6G_1xvCUQxbcW-awyK-cGN0QXShaHziiIZp7VWoXWdwFq17v_jdGUbAAyRIoIMpC58_z7e4e3vuoO9LunxMjdfssSdqHk7i-moV9GcVbDgGmzB8ofsx_yPaCtX51dsMlm6OvQ3NQ8WkK37ATkWun7V9xNjOvN7a1-3_qPbcDrkJn-Y8atqPYSU4jsL817oy6_78CvYYdLt3v3vAeHAOW0kn9Jk7CZqH0PuHsBoBI0dm1B8r62ysAVAgxbsvOkZCEBsEoqwdY1_T2qqXJHwq4Js6Tgh_chEN9yaVDe6aeIeWlMfFP1PQtdKkwElVhZ3UvBoSlwgNfORLKUGTWwZdiBeAeorkbb11kbHPos6RjCs_mtLXiUzoVltVDrn1CRyBACIH9zrAKuWkbUtK_88O47h1ihQlOaZnD55_bCPhcVJtB_RecKjulLctpzxc4m-JdHK_wSJQVmAWMc6vmaAXM7Ilj9efRk5Jdk3MLxKgS6KmWO3YXy5swfgTxc7vkp7mnUGBTANFI8e2DFl7kt0j5IIEr-7SHzASyMfxXKaWX65xN_dSwrqBk=w1215-h911-no
rY6XGPor1PSuGDIe55tzLq1OrDkv0Q_sYm6wurcTbISiaNyNA4GegaNFsBaDelopiJ1OZoGcBUmhS3hM-Z2NZYKjKuvzDBbstBGtMBXDSJBXt_Mt8Qe2EqW7X-8bugKknkW7Hp6HNsWtcuEhuM_HxlZjVVXJkdP9NuMJUdgueeUlns0rUKOXPlLFudLhGitDDKo8bKMTZRPqQazzS-22cDk7OZYbxxp9fqMvO5KzOWUZDfahcVZDDdmgIRl0WunOkuA_E4izWJK96Lrma3Mv29F1k5cJHKZmYCr-3uVUHBNCgGLnO-uWDpMsvaanumBzeWhE9Pm1RK4BKF36dL6OPr9Y3rmL-vznIdhryZ2ynSu8JxE5fZWgZVQd1LHRnxPkfdQamZp_kiMLpbQwUMvNXRexwCoCXCBkz86j15wOtAcCxfATsSogp9jCiUVkg4MVbclNMy8uXlFm5HM64Oext2ipGbs_lGAmtlXtj1Am6qm0mU-jrh2oimEewPUV1wkvyMExEVikjXy5hne0oFUK5LRGuFL65v8kwKAN-8MZ1VIUtvF_EV_6ppRiOE6dJohsUD0zwDVVKxRIlVGOGXb4fc7sVCqOyEp2MJHGZyzU8HOnqNKROeP32woCiQaBC8or1g0ahO9y2BeVRw8T44trHceOBxKY0c6YGReqhbvq7LjHw8A50MBCruQ=w683-h911-no
9262hDJcMEbsjyC-wN2RFY_qysWQk-StjKCVb3tROnPXdwHs-Aaxzqo87GknxjRT3AdPa51ufS7AI-HxtliocLxgL97rppx3YZzKjztOQxFF4nZ3xXE-0E4QiHuE-UqPGTNcsL1HNNWPC7aVQ15ODzD6QbBnLpm1G-eE0xlJfsV5YYBG9RPg9n-4buGqxL7aMyJhn-jqqgevHm7QqhgKxumv_vaDNCeahpr2nzFTWA1Ck2YO16bECK8-OeZIVccoE4-Zj9B2LUIfWojOwURk9YpmZ4Kv_XXwQDRA-qNPEEmhw9Xmz-U8l1GbzA3afv8SziRu-shZJ8Ybre2tLtkbSnHp3jsoMWR81lyIb1zGOW2L9L0HuhKas4Ljk9eLoc7O0V1H6PCbkqiSSoAKj7AN_O8ICFtHu-xzgB8gL3qTG5t8noHmtQjrX4nB9ROSn1_f1EbPGcBT6rwqtGRBnz1HtEbIV2lNdeOj6Duv41VGvD4BCdoG_UBKjGR3zz5nQQBALeGGIlE3HkoyVjc9ge1dh7ZIKlAJ3sDpUzq0iHREbm1XSLYcReM8AHMJ9MLy9ASMtBJSBfa54R8cBzmwNiuyjo98_NLk6Pbc5f6ONcSk6ke_ixbzxxYzDJwU6NrIRxRKH5LkCYSNrp3VgTzXHra48od4npaCzVER93xzdM72B8O3Fv_EP33Qz_Q=w683-h911-no
Did you put a cover over the back end (loose cover to allow a bit of air)? Perhaps a bit of cover over about half of front?
Judging by the picture and where flame hits the wall , you can t get swirling effect ??
m definitely not getting the swirling effect. Is there a certain way to position the tip to get the effect? I have tried both covering and not covering the forge back as well as partially covering.
I have never used a forge like yours. I have a vertical blown forge. I was having trouble getting it hot enough till I put ITC 100 over the satinite. that made a huge difference.
is it cold outside ? I don't have experience forging but I have had problems with 1lb bottles freezing up while hunting in cold weather. they work just as you described great at first then they peter out
I can't see your photos, but will say that a 1 pound bottle won't run a forge long, and may well freeze up after a while as Bill pointed out. Get a 20 pound tank and a hose adapter for your torch.
Also, most all plumbing torches don't deliver enough BTU's to run a forge.
The best solution is to buy or build a proper forge with a proper burner.
This was 100% my problem. Im up in Maine so my tanks were siezing up. I warmed it up and voila roaring forge spiral that got plenty hot. Thanks for the tip.
