I would compare that steel with Aus8 with slightly better edge holding. I think 154CM and VG10 are better [edit]
I would compare that steel with Aus8 with slightly better edge holding. I think 154CM and VG10 are better in general. I can't comment on 440C because I don't have any experience with it.
Dog of War found that it had more edge retention than VG-10 after multiple user testing sessions. As long as you clean it with water and take care of it, it will hold a hair-raising edge for quite a long time. I find it much better than AUS-8
I find that AUS8, more than most steels, varies from manufacturer to manufacturer.
The one I like the best is by Moki of Japan (which also makes blades for Al Mar, Beretta, and some other companies.)
13C26 is designed by Sandvik to be a razor blade steel and it's not surprising that it takes a phenomenally sharp edge.
But good AUS8 can do the same.
Still, though, both steels have about .70 carbon content so neither is going to
be a world beater in terms of sharpness longevity.
