What is your favorite brand/type of stropping compound?
Charr
Platinum Member
So I was just thinking about this, and it isn't something that I have seen talked about as much (sorry if it has been), so I figured I would ask about it.
What is your favorite brand of stropping compound, and why?
I ask brand because there are several singular types of compounds, but the variety that a company offers can play into how much you like them as well.
What type of compounds do you like as well? Diamond? CBN? Something else?
Just give me an idea of what you like and why, because I want to know ;)
For me, my current pick it Bark River's CBN compounds, mainly because they come in a variety of particle sizes, are relatively inexpensive, and are stocked by a good retailer that keeps them in supply. They are also able to handle a variety of steel types, from traditional steels all the way up to more "super" steels as well.
I don't like BRKT strops as much, simply because they are thicker, and are much better for maintaining a convex edge than a v-ground bevel, but the compounds work just as well on a thinner, more flat strop for my v-ground bevels, so they work just fine that way as well.
So, what do you all say? :D
Green chromium oxide, because it works. A stick lasts practically forever.
Yep. Black emory, then chromium oxide. Some Flitz afterward. Lifetimes worth of all three cant cost more than a double sawbuck.
Can't say there's anything wrong with that ;)
I used those before I started using the CBN, and I just like the CBN a little more for some knifes now. It's a little faster when used on higher-carbide or more wear-resistant steels, but honestly that might just be me being lazy as well I don't know :D
You could put wet/dry over hard flat surface for v-grinds. Or on a strop for convexing. Its what I use to convex a vee grind. Whole series of grits. Again...cheap.
That's good to know, especially for something like a fixed blade in 1095 or similar traditional carbon. I will have to give that a try and see how it works.
Off to MTE -
Maintenance, Tinkering and Embellishment is for discussing sharpening and other stuff,
General Knife Discussion is for discussing the knives themselves, that maybe why you had not seen any discussion (looking in the wrong place.)
