Here's the best way I've found to thoroughly mix epoxy:
- take a piece of heavy paper about 4" x 5" or so (I keep a stack of scrap paper cut to that size, with a hole drilled in the corner and a twist-tie through the hole, hanging in my shop);
- use a 6" length of tie wire, bent into a curly cue at one end and an "L" shape at the mixing end;
- put the epoxy parts in the center of the paper;
- lift the paper into one hand;
- mix with the tie wire.
What this does is allows you to scrape the two parts together, mix, scrape, mix, and so on. You bend the paper into a trough as you mix and scrape. As the epoxy starts to spread a little lengthwise in the "trough", turn the paper and make a trough at a 90deg angle to the first and continue mixing. This eliminates unmixed parts of the epoxy as will happen using little cups, etc. Using cups, unmixed epoxy quickly gets pushed up on the sides of the cup and down into the bottom "corners", and either gets unused or gets inadvertantly put into the project.
Plus, the paper is fast, easy, and cheap, and doesn;t require any prep.
For large batches where, say, several ounces of epoxy is needed, cups are more effective.
