Agree with Sergiusz... this is all assuming you've mastered free hand sharpening.
If not, then you can try the Lansky or DMT sharpening jig system... where the knife is held in a clamp, and clamp has holes that orient the stone with guide rod at a fixed angle. They work well, will help teach you what to look for in terms of a burr during sharpening, and make transition to free-hand much easier.
Also, DMT makes a nice stand for their stones. I have the big 10" x 3" duo stone (coarse + fine) and the stand. Got the stone from these guys:
http://www.cutleryshoppe.com/index_catalog.html
Navigate to bottom, sharpening, then you'll see the DMT Duosharp benchstones, stone stand, and the aligner system.
DMT's stones are better quality than Lansky's, i.e. last longer. But the DMT alignment jig is some kind of plastic/polymer, and I'm not real wild about it (haven't use it, but have played with it at a store)... it's a bit flimsy. The Lansky jig is aluminum and seems to hold up better.
All of the jig systems have pros/cons. Use the search engine to unearth recent and archived threads on this topic.
EdgePro is arguably the nicest... more expensive, built better, but has some negatives (dirtier, have to protect knife from other surface scratches). System uses water stones, which cut very nicely, but do wear quickly and have to be flattened periodically (which is one thing the big DMT DuoSharp stone excels at).
http://business.gorge.net/edgepro/
