Here's the saga of how I ended up with my wood band saw...When my 10" Craftsman burned out, after I did a ton of research and evaluated what tools I already had, I felt that I really had no need for an expensive large wood band saw, as I would only be using it for knife making to cut and profile handle material into slabs or scales. I already have a metal cutting band saw, so if I need to cut anything harder than Ironwood, I can do it with that. Similarly, I have a table top 10" saw and if I need to make a big piece of wood into smaller more appropriate for knife-making size, I can use that. And my scroll saw can do whatever fine curve work that needs to be done. So, I first bought a 9" Delta, but it broke the first time I tried to increase the tension on it. Then I did more research and after seeing lots of excellent reviews for it, I ended up buying a Ryobi 902 from Home Depot for $99. It's been great! It cuts quickly, straight, and it's easy to set up initially. The new model comes with a light, tracking window, and a fence. Also, it comes with a 30 day no questions asked return policy, and a 2 year overall guarantee. So, to sum up, I think that if you have no real need to have something bigger or have more than handle making tasks you want it to do, I totally recommend the Ryobi band saw. Then you can use the money saved for other tools or great material to use for your knives.
Thanks,
Bob
