- Mar 11, 2013
Friend gave me this. It’s about 1x4x1/4 Its coarser than my soft Arkansas, in between the coarse and fine of a double sided carborundum stone.
Yes, aluminum oxide and silicon carbide abrasives are MUCH harder (and sharper) than silicon dioxide (Arkansas stones/quartz) is. It doesn't appear to be an uncommon or especially notable stone. However its behavior may be different from other vitrified bond synthetic stones simply because there are many variables that go into them. The cut speed, finish produced, and the best degree of pressure to apply to it can all be impacted by the specific formulation of the stone.
To add to that: the surface preparation of the hone itself in the case of India, or aluminum oxide hones also plays a role in those characteristics. That is because the hones are generally not very friable and will hold their shape for quite a while. Most silicon carbide hones are quite a bit more friable and will more readily break down to an equilibrious state of coarse/fineness - that is to say, always pretty quickly settling back to the same place whether one should try to lap them coarser or finer.
As further explanation, this is a result of both the bond strength and the friability of the grains themselves. Older oil stones tend to have a very hard bond to them and silicon carbide grains are more friable than aluminum oxide generally is. That being said, not all aluminum oxide stones are hard, per se, but hard stones do tend to exhibit a greater change in their performance characteristics dependent on their surface conditioning compared to more friable/softer bond stones.
