What Lansky angle on the CQC-7?
I'm new to the Lansky, and I've previously kind of made a mess of the edge on the CQC-7. (And one of the reasons I was psyched for the chisel grind was the ease of sharpening.)
Tips on technique here would be appreciated. Thanks.
Use the sharpy trick, search the forums for it. If that does not work, you can do it freehand. It is pretty hard to mess up sharpening a chisel grind. Good luck.
+1 to what RevDevil said.
The sharpy trick is key for someone new to chisel grinds, it can be hard to get down to the edge all the way if you are used to v grinds.
