- Mar 1, 2010
Of all the common types of locks like liner, back lock, frame lock, axis, CBBL, Tri-ad, etc., which do you think wears out the fastest?
Have no idea, but don't think any of these would wear out in a lifetime if its constructed well, and made by a good manufacture such as Spyderco, BM, CRK etc..
Some liner locks may last a lifetime while another, even on the same model knife, will wear out in a year. Once they wear out they have to be thrown away because there is not much that can be done.
Stabman, "assuming the same tang angle" Huh??????????
The lock bar face must be flat (no angle) or since it is vertical then let us say 90 degrees, the angle cut on the tang must be 10 degrees to 12 degrees to the makers I've spoken with. If the lock bar face and tang are cut at the same angle then there will be no material to provide resistance the lock bar will simply travel all the way over the non locking handle slab upon engaging the lock (opening the blade).
THE ENGAGING AND DISENGAGING OR OPERATION OF ANY LOCKING MECHANISM IS GOING TO CAUSE FRICTION. CRK heats up the end of the lock bar face which is titanium on the sebenza and makes it very hard through this process thereby increasing its hardness to something similar of the blade material S30V, so far so good, I know people who have 13+ year old sebenza's that are EDC'd and still have solid, functional, and safe locks and its a frame lock. There are way too many variables here, and most frame locks are cut with a tang angle of 10 degrees for safety reasons, however I have been told if you take it to 12 degrees locks would last longer.
Do manufacturers generally not replace a worn liner if returned? Not covered under warranty?
\\Various alloys of titanium only respond slightly to heat treatment meaning they only gain a couple points on the Rockwell scale. If I remember correctly titanium runs around 35 on the Rockwell scale and if heat treated can run around the low 40s depending on alloy. This is still significantly softer than any blade steel and is probably part of the reason titanium galls. The low hardness is also why titanium makes a poor blade material. The toughness of titanium might make up for it's lack of hardness some, but I would think a hardened steel lock would last quite a bit longer than ti. With hardened steel you have to start to worry about wearing the blade tang which is probably why some makers put a deposit of carbides on the tang contact area. I would think a deposit of carbides on the titanium lock would also significantly increase wear resistance but not sure if anyone does that.
Liner, absolutely (in most cases).
The only reason most frame-locks don't wear as quickly is due to a larger lock-bar/tang interface.
If the lock-bar is the same thickness (thin frame-lock or thick liner-lock), then the wear rate will be the same, assuming the same tang angle.
AXIS lock and lock-back will go on practically forever if the springs stay good.
Spring longevity is pretty hard to guess and unreliable. They can go on forever or they can break in a week. I would imagine a lockback would probably last the longest but yeah who knows what can happen with a spring. At least with a liner/frame lock you have a general idea of how much life it has left in it. I think a well done framelock from someone like CRK would last forever. Plenty of people with 10+ year old Sebenzas that are still going strong and likely to last their lifetime and beyond.
either I just failed to comprehend what he was trying to say are he missed typed or something. Whichever I needed to straighten that out or get him too.
