What makes a blade sing?
Back in the 60's I bought a made-in-USA Collins brand machete that was different than any other machete I've handled. If you tapped the blade it would ring with more of a clear bell tone than any machete I've handled. Usually machete's are a bit soft to withstand abuse. This seems to dull their song. My Collins seemed to have more of a spring temper and never took a bend when given tough usage. I'd guess now that it was made from 5160 with a high spring temper.
My question is, have you owned or made blades that made a pleasant ringing sound when drawn or tapped? If you did, what were their dimensions, materials, and heat treatment? Do you have fond memories of a blade that felt and sounded "cool"?
Given the hardness of many modern knives and swords I would expect them to vibrate elastically in a way that would produce a good song. Why don't I notice the sound more? Are they too short and too thick? Can it relate to something like cold working (such as cold rolling) that gives a high surface hardness that is good for song?
I had noted in another thread that for some reason my Anza #4, a simple 3in full tang straight hunter I guess it'd be called, had a more pronounced 'zing' than my other knives when I rub my thumb across the blade. I guess it's due to the simple blade shape, no guard, the full tang handle which would minimize damping, and the hollow ground edge.
I have four knives that sing. Two are Panga Knives made by Blackjack. They're between 1/16 and 1/8 thick, and I can't remember if they're made out of 6A or 420J2 (pretty flexible steel). They have 14" blades, 19" overall, no guard, just handle. Much like your machetes.
The other are a pair of Millennium Fighters made by Jerry Hossom( www.hossom.com ). They have 11" blades, 5" handles. They have bolsters rather than guards, and the steel is between 5/32 and 3/16 thick. Of cryo treated ATS-34.
What seems to be the correlation here is that all of the knives mentioned don't have anything on them that would dampen the song of the blades.
Matt
The excellent Iltis axes (made in West Germany) ring like a bell.
[This message has been edited by Alberta Ed (edited 02 October 1999).]
