What psi are you running at?
This is just for my own curiosity... and not during the heating up, I'm talking when running after the initial "warm it up" phase...
I'm running a home built forge with a T-Rex and once I'm up to forging heat inside I have it running at below 5 psi (not sure cause my gauge starts at 5), loks like 3-4 to me. When I don't have a work piece directly in the forge, I bypass it through a needle valve and it barely even registers on the gauge. We're talking almost off.
I was just curious what others are experiencing as this is my first (for real) forge and I wasn't 100% sure what to expect.
If you have a minute, post your "stats" here for all curious enough to look.
Oh... almost forgot! By my (crude) calculations I'm around 405-415 cubic inches blocked by fire brick in the front so I can adjust the size of the hole I need for the individual work piece. Said psi is with about a 4" x 5" hole in the bricks.
I've been running around 2 psi (we are talking propane, right?) in a ~300 cubic inch horizontal forge with a 4.5" x 3" mouth, I use a kiln burner. It seems like it takes forever to heat up since I lined it with satanite.
