The pressure only matters on your individual forge. Running at the same temperature mine might run at more or less PSI. Each burner has its own operating pressure based on whether blown or venturi, orifice size, regulator size, delivery piping size, needle valve size, and hose/piping size.
It is exactly the same as volts, ohms, and amps. For a needed volume of electricity (amps) you either increase the pressure (voltage) or decrease the resistance ( ohms).
In a gas burner, pressure is one part of the delivered volume, the other is resistance to flow. What restricts flow is passage size. The things that restrict flow: Piping from gas supply, regulator size, valve sizes, Number of valves, hose/pipe sizes, length of all hoses from supply to burner, burner type, orifice size1CFM at 2PSI through a large valve is the same as 8 PSI through a smaller one. Just like in an electrical circuit, the main way to decrease the resistance by using a larger conductor wire/pipe.
As a general rule for knifemakers not connected to a gas well in an oil field ( we have some of those here) - 1/4 to 1/2PSI on a 1" residential natural gas pipe is about max; 1-6 PSI from a bulk propane tank is the normal range for a blown burner; 5-20 PSI from a bulk propane tank is the range for a venturi burner.
