What should a BAS do?
Question: should I expect my BAS to cut through 4 inch branches with one swoop? It doesn't look like it's happening. Also, how should I go about sharpening my khukri? I am a newbie, and starting a new post with all these questions may not be proper "Forum Etiquette" but I thirst for information. Thanks :D
-Karl
Welcome Karl,
I'm sure that there are many epxerts who can answer this question so as to leave no doubt to your BAS and it's abilities.
You might be able to cut thru a 4 inch branch "with one swoop" with a supercharged chainsaw but not most hand drived tools.
Check FAQ for all you ever need or want to know about sharpening.
"Question: should I expect my BAS to cut through 4 inch branches with one swoop?"
Depends. If you've got muscles like Arnie's big brother and you were born on the planet Krypton - well, you probably won't bust the knife trying. If you're an ordinary mortal like us folks, no. Expect the same level of cutting power as you'd get with a tomahawk or hatchet. Practice will improve your technique.
"Also, how should I go about sharpening my khukri"
I suspect there's as many answers to this as there are forumites. In my case; if the blade's just dull (ie no longer sharp enough to shave a hair or two off your arm) hone it with the chakma provided or some other piece of hard steel; I use a tungsten carbide lathe tool. If it's gotten very blunt, I use fine-grade slipstones and an India (oil) stone, followed by stropping on leather, followed by steel. Burnishing the edge with the chakma means you aren't removing metal every time you sharpen; you're just putting the edge back in shape. Br careful when sharpening to follow the cannel (slightly convex) profile of the edge - if you sharpen it like a conventional hollow- or flat-ground edge, you'll reduce the khuk's cutting ability. I think it was Yvsa who said, "Sharpen it like an axe, not a knife".
Not that it'll need sharpening all that often...
Those 4" branches too much for normal guys I imagine. I bet Terry or Cliff could. Of course they also have a big yellow "S" on their chests too.:p
For me 4" branches is more than I can tackle in one swing. I have
been using my 17" chiruwa Ak for sometime now and I would definitely
have to take more than one swing to chop up a 4" branch/log.
Ryan
Not to be a smartass, but it really does depend on the wood. Dry or green obviously makes a huge difference. But the species of tree makes a big diff also. In Hawaii I chopped down some Java Plum (Foxjaw might be able to tell you about this wood too) that is so soft it makes you look like superman. I could easily chop though 4"+ limbs off a live tree. But that was unusually soft wood. On a maple tree with my 20" AK with all angles being in my favor and having eaten my wheaties I think most of the way on one and finish it off on the second. But I'll have to go and try it and get back to you:D
With a BAS which I assume is about 15-16" long and weighs about what a 15" AK would that would be one hellava feat. Buy Heber's 25" AK and you'll be in business:)
