Is there steel that has spalled off behind that bit? If so thats probably a heat treat issue.
The shape looks pretty good to me. What shape do you think it should be?
In any case a good file is all you need to shape the bit of an axe.
Little bit of work with a file and hit it with a stone and that one is good to go. That's a True Temper Flint Edge in pretty decent shape. It's a quality axe.
Keep in mind that a file requires a file card to clean it and a vise or clamps to secure the axe while you work.
Any ideas?
I was more referring to the shape of the edge from the side. You can see that the axe is about flat, or even concave in the middle. Should I reshape it so that it has a nice curve to it? Notice the difference in the striking edge of the axe that jblyttle posted.
Yeah that's easy work there. If I had that axe in hand, presuming it's going to need a fair amount of work to sharpen/reprofile anyway, I'd just give a few quick brushes over the belt sander (or file if you're overburdened by time or you're morally opposed to what I am suggesting) just to even things out, proceed to re-profiling as normal.
It's a little flat but I wouldn't worry about that. Most old axes you find are worn on the heel and toe and are too round. Normal use and sharpening tend to wear the toe and heel fastest. Be thankful that you have a lot of toe remaining. Don't remove any of it.
I have a Craftsman 1x42 with a 6 inch wheel that I picked up cheap when I though I was going to play at knife making. I found that I don't have the interest, time or skill to pursue that little hobby, but it has become an invaluable tool for axes. Rust removal, edge prep, shaping wedges, smoothing messed up handle butts. I use the heck out of mine. I can even polish the edge with worn belts that still have some sawdust in them.
