What size torx?
May depend. Most are T6. Some older ones are the very small hex head and yet others are Spline.
Which knife?
STR
Those are T6 throughout Jay. You lose a screw?
STR
Thanks for prompt reply. Pivot screw on port side is raising its little head. A half turn should put it back. Maybe I am playing with this little jewel too much. :o
Nope it sounds like it needs a dab of blue loctite on it, set to the tension you desire and to let it sit overnight. That will fix you up. ;)
STR
So I am looking real close now at these nice torx screws. I note there are two pivot points. The lock bar, and the blade. Both have torx heads on both sides of the folder. So now I wonder, does each screw go halfway or is it a male/female arrangement?
Two separate screws not quite meeting in the inside on that one.
STR
