I think those guys nailed it. If you have the space, there's never been a better time to get into a nice used surface grinder for cheap. Your mileage may vary, depending on where you live. Atlanta is quite a metro area so that could be good, although SG's are priced like solid gold mostly in Seattle. I had to go to New Jersey for work a couple years ago, to find a killer deal on mine.
Auto feed is a huge plus. Coolant is not hard at all to add, provided your machine is designed to be able to catch it at the table and funnel it into a drain. I built a reservoir for mine from a $15 plastic tub from Walmart. A submersible pump such as a Little Giant, some hose, a valve and light piping, and you're good to go. Or, convert to belts.
Regarding the art of surface grinding, yes the knowledge is fading a bit, and not a lot ever made it online. A perfect surface finish is not required usually, I don't go with a surface ground finish on pretty much anything- just grind it up to where hand sanding takes very little time. Or, just within a few thou of the thickness you want if processing billet fodder.
You can also make use of carpet tape, glues and things, and thickness grind almost anything that won't stick to the magnet, including wood or G10 if you have a belt conversion.
There are options near you- for instance, if I lived in Atlanta, I'd already be over looking at this machine:
https://atlanta.craigslist.org/nat/bfs/5980519974.html
I mean, YESTERDAY!
