References to hardening are typically 1450-1500 F .The normalizing temperature should be the same .Certainly hardening at 1600 F would give you high retained austenite and large grain size . What would be the advantage of normalizing at 1600 F ???
Alexmin, for stock removal you don't need normalizing though you might do stress relief at 1200 F....Fox and Phillip , interesting , I'd like a technical explaination !I checked many sources on Google , some say 1600 F , some say 1450-1500 F .Some make no reference to normalizing .There are various methods of annealing too !! You just can't get two metallurgists to agree .
Mete
Digging into the dark corners of my memory, which has more grinding dust than useful information, I seem to remember that on some steels they:jerkit: use the decreasing temperature step normalizing because, the first cycle is used to dissolve the high temp carbides of vanadium, tungsten, etc. the following cycles are to reduce grain size. If I find where I read this, I'll pass it along.
Jim Arbuckle
Reheat to a proper austenitizing temperature typical to hardening on the next heat. Here, as with any heat in normalizing, the most critical factor is that you heat EVENLY, bring the entire blade evenly up to the same temperature or you will defeat the very purpose of "normalizing". This heat will refine the grain size and disperse the carbides a little better. The less time you hang around the Ac1 temp the less segregation will be put back into the blade, so a quick (but even) heat is the best.
The third reheat can be to the same temp or cooler and allowed to air cool. for extra grain refinement and stress relieve.
This is why so many guys who forge at low temperatures will end up with banding and other nasties that need to be dealt with by higher temperature normalizing.
