What the difference
So I see lot of Bussekin knives labeled LE and then the same models without the title. What's the difference? I figure LE stands for limited edition but what limited if there are normal production models of the same knife? Please excuse my newbieness.
LE's are a specific release of a given knife that are numbered, satin, and all have the same configuration (length, width, handle material, etc)
They often have a greater blade length than the Combat grade releases, and are usually a different thickness
You're right, LE stands for limited edition. The same models without the "LE" simply means it's not limited edition, which could mean it's Combat Grade (CG), a one off from a show, a custom shop piece, etc.
The limited edition versions of a knife have different specs from the CGs (lower-cost production models). They are not one-offs however, because their specs are set and they are put into limited regular production. Their specs may also differ dramatically from the CGs such that the use and feeling of a LE might be completely different from the CG's. The most common difference so far is that LEs have a satin finish and CGs are coated. LEs also usually have a serial number.
