Octihunter,
I just use the handheld shield that came with my welder, it's useless, so dark you really can't see the weld outdoors even under the full light of the arc. I'm planing on taking a big step up. bocgases.ca has their own brand of helmet that uses the Optrel brand of solar autodarkening lenses. Apparently these are absolutely top of line, the only thing they are doing is droping them in a standard helmet with their name on it, rather than Optrel's prettier model.
In Can. dollars an optrel helmet is 500, a boc with optrel lense is 370 if 9-13, and 230 if 10-11. I'm choosing between the two helmets at 230, and 370. My helmet will have cost me more than my welder, but as with many such things it will not probably have to be replaced for a fairly long cycle, and I will have a good helmet regardles of where the welding takes me.
I'm self taught, and that's my only local option with a few tips from other local welders. I feel that if I buy a good helmet where I can see what I am doing, I can do a better job and avoid peeking, which currently is a problem. I'd be surprised if I welded 6 hours a year, so anything I get that is over my eyes will probably be good enough. But I want to have the upgrade path covered also.
Thanks for all the advice so far.
Let's say I had the 9-13, how would I know I was at the reight setting if it is possible to be getting too much flash without being aware of it? Obviously I could start dark and peel it back, but if I can't easily tell what's right...
