- Jun 27, 2010
Personally, I rough slab my scales and shape and finish the front edge of the scales pretty much just as you've done, Emphasiski. Maybe a little more clean-up to the front of the scale. Johnnymac is right on. Once they're on the knife, you can't change that front profile. Then I do 90% of my handle shaping after the scale is glued up to the knife. It's worked for me, but you just have one chance to get it right or you have to grind off a perfectly good set of scales.
--nathan
Yes, to sum all the posts up....
Shape the front and polish it. If there is a finish applied, even apply that,too. Once on the knife there is no way to get a perfect fit-and-finish otherwise.
TIP:
Tape off the blade up to about 1/4" from the scales before glue-up. Use the blue painters tape. After the glue is partly set, clean off the excess with acetone. When cured, clean up again and then tape right up to the scales. This will save a lot of curse words by preventing scratches on the polished blade.
BTW, I cover the handle part of making a knife pretty thoroughly in the sticky, "How-to instructions for making an knife".
