- Apr 8, 2007
what type of gas forge is better and why? a forge with one door? or a opening on both ends?
Depends on what you're doing, but I'm a firm believer in forges built from round pipe with the burner tangentally set to create a vortex of flame. MUCH more even heat. If you're doing a lot of forge welding you may want to look into a vertical forge.
Take a look at the stuff that Darren Ellis sells. I highly recommend his forced air setup.
-d
Why do you say if doing forge welding you may want to look at a vertical forge? Does the vertical offer something for forge welding that can't be done with the horizontal? I am building a horizontal and will be doing forge welding. I want to be sure I am building the right thing.
but...it won't burn steel.
I'm not quite sure where that impression comes from. I've had a couple of serious sparklers come out of my gas forge. I even melted iron in it once.
