if the coating is sprayed on i would use a stripper or sandpaper if its dipped or plated. you can get a mirror finish by going through the grits starting out at 400 and working your way up until the blade looks like you want it.
a dremel leaves a lot of lines if you try to buff with it that look like crap. i tried my hand at buffing with a dremel many years ago messing around with some scrap pieces of steel and i'm glad i never tried it on an actual knife.
I don't believe even the Black Emery compound is coarse enough to strip off coating, at least not thoroughly. I would strongly recommend a bench grinder with buffing wheels. A dremel is too small for the task.
The wheel is coated with an adhesive, and then Aluminum Oxide powder is coated on top of that. The greaseless compounds will also work, but I find the abrasive wheel system holds the abrasive MUCH longer. Though you might inevitably need to use the greaseless compound if you want further polishing. I found the finish from the 320 grit aluminum oxide to be very rough and vulnerable to corrosion.
Your best results would be achieved by taking the knife to a reputable machine shop and having a master machinist remove the coating with a commercial buffer. Theses machinists are professionals and know what they are about.
