So I know good epoxy is important to bed the knife scales. Check!
Next is mechanical attachment.
What’s better though?
6- 1/8” peened brass pins, OR 2-3 brass corby bolts? OR something I don’t know about!
Has anyone tested these against each other? I had read that peened pins are stronger because if you do them right you have an hourglass shape inside the handle and it can never come free of the scales?
But I also have heard that Corby bolts are better because of the mushroom shape offering more surface contact?
It seems to me with corby bolts the risk is the threaded part breaking free of the head like when you over tighten a small bolt or machine screw…
And the risk with peening is that it will break in the center where the pin passes through the steel…
When I picture it in my head I would go with pins more redundancy with a greater number of smaller attachments… what do you guys think?
