What would happen if...
I put my kershaw Vapor in my brass tumbler to clean it up a bit, would it remove the dullish coating.
That's not a coating, that's beadblast. It is small little valleys in the steel, so unless your brass tumbler will polish it, it won't change.
You can remove the beadblast finish easily with a Scotchbrite abrasive pad or even some fine sandpaper. It comes off rather easily.
The space between the handles can be cleaned out with a Q tip or some similar item no problem.
I would be hestiant to put the knife in a tumbler of any sort, as even a smll amount of damage to the pivot or locking area could screw it up rather easily.
Not really a tumbler as in goes round and round, but its a brass cleaner, it vibrates to get the brass clean. Its a vibratory case cleaner.
