Hello everyone, this is my first post here. I consider myself a maker of various things, mostly rc helicopters. I have a cnc mill turn machine that i designed and built mostly for the purpose of manufacturing rc helicopter airframes and upgrades. If anyone is familiar with rc helis, i designed and built the Q700. During the last 5 years or so of learning cnc, i watched a lot of videos from John Saunders and John Grimsmo and kept up with Business of Machining podcast, so im very familiar with grimsmo knives and a lot of what goes into manufacturing them. Even though i got started in machining for rc helis, ive always been interested in pocket knives and wanted to design/build one. I like to come up with unique designs that dont follow the average way of doing things as i did with my rc heli airframe which i believe was pretty successful. There is demand for my airframe, but the hobby is not large enough for me to take that path seriously.
At this point i think id like to take a crack at a folding knife design, whether it someday be sold or just for fun. I already have most of whats required to build myself a knife. My machine is a bridge style mill with a servo driven bt30 spindle as well as a servo driven horizontal turning spindle which can handle both turning and 4 axis machining. Great for parts that need both milling and turning like custom screws, pivots, bearing parts, standoffs, etc. as well as plently of table space for fixture plates. Some of the other stuff i would need are things i have also needed for many rc heli parts i would like to start making, specifically a hardening setup, cnc grinding additions to my machine, belt grinder, etc.
For the last couple months ive been throwing some ideas around in my head, somewhat unique bearing arrangements and lock mechanisms. I feel there are ways to get the ultimate friction free smoothness with absolutely zero slop and max rigidity. It seems that even the smoothest bearing pivot folders have sources of friction and slop here and there. For example the Norseman is bearing supported axially but still just a bushing type pivot which has not much but a little bit of friction radially. Also part of the action has the detent ball dragging on the blade. Ive never held a Norseman so i dont know what the action feels like, but there has to be at least some amount of clearance around the pivot which will create slop. This slop may only be a few tenths and maybe not (probably not) felt or heard in the action, but what if you had a truly slop free friction free action? This means no sliding surfaces, only bearing support in both radial and axial with some amount of preload to eliminate all slop. The closing detent can also be done in a way that it does not drag before closing, or at least only drag the last couple degrees. The question is, can it be too smooth? What if you could hold your knife out horizontally spine up, flip the blade out and it was able to pendulum back and forth for some amount of time while still being absolutely slop free and 100% rigid when locked? Is this too much? What about the drag from detent ball before closing all the way? Do we want it there, or is it better off eliminated?
Before i try to design the perfect folder, id like to hear some opinions on what the perfect action really is. I realize that many prefer the reliability of a none bearing knife that is less sensitive to dirt, even though a washer style will have more drag, but this will lean more towards a mechanically impressive knife with an emphasis on smoothness and ease of deployment. Somewhat of a fidgeters knife but still extremely reliable and handles abuse.
