- May 31, 2020
Hi again,
I've had a nearly-complete dagger in vaguely 19th-century style sitting on my bench for quite a while because I'm having a devil of a time finding a good frog button, and I'd like to make more period pieces in the future. Judging from photos, it appears buttons at the time were usually soldered or fastened to the metal throat, and were relatively wide, shallowly domed on top and flat on bottom. Modern button studs are made to be attached directly to the leather and the heads appear relatively smaller and more deeply domed, both on top and on bottom.
Scabbard with modern button and current work piece.
Example of an antique with the type of button I'm looking for.
Up to now I've been cutting them from brass plate and sometimes hammering to dish them, which always gives me an uneven, amateur-looking result. I've considered using various other hardware but there always seems to be a catch; brass carriage bolts, for instance, seem to be difficult to find in the right size (for most of the ones I'm working on or planning, this would mean a button head around 3/8 to 1/2 inch wide). Right now I'm thinking maybe shortening the shanks of solid brass Chicago screws and posts, and soldering them together to make a solid unit with a wide, flat base that will join well to the throat, or else soldering the screw to the throat and attaching the post with Threadlocker. But I'd like to know if anyone has a better suggestion.
