what's involved in lock tuning?
I know, I know, I keep saying I'll do it, I just haven't had the time, I'm in the middle of a move. I am planning to send my large and small regular in for spa treatment, including lock tuning, since they are both very sticky. I've noticed that they both have shiny patches on the lock bar surface where it looks like the carbidizing has worn through. Does CRK touch up the carbidizing as part of the lock tuning service?
I wouldn't touch the lock bar as it will probably void the warranty. The quicker you send it in the quicker it will be back to you.
Also CRK doesn't carbidizie they carbonize. Sound similar but are different.
I'm not planning on doing it, I'm going to send them in for the spa service which includes lock tuning. I'm just curious what CRK does to get rid of sticky locks. To me it looks like whatever method they use to treat the lock surface (carbidize or carbonize) has worn through. Do they do some sort of touch-up at the spa?
Best place to get an answer is to pick up the phone and call them IMO. We on the forum do not know for a fact and can only speculate because we do not work for them.
My speculation:
They replace the frame lock and adjust the blade to the lock. No simple "tuning".
Actually, I believe they carburize the Sebenza.
Correct. Sometimes the AutoCorrect isn't.
The invoice that was included with my returned Sebenza said that they "had to reset lock tension back to spec". I have no idea what that means but apparently they check the lock-up action pretty closely and make adjustments as needed.
I recently purchased a small Sebenza Insingo from a dealer that came with a very sticky lock right out of the box. I contacted CRK & they told me to send it back to them. After about 3 weeks, I received the knife back with a perfect lock-up. The N/C invoice said they 'heat treated' the lock.
Okay, so the triangular patch of the lock bar around the detent is a different color/finish because of carburization, not carbidization.
My limited understanding of carburization is that it is a form of heat treatment that hardens steel by allowing it to absorb, into it's surface, carbon from a sacrificial carbon source such as charcoal. This sounds a lot like how carbon was added to iron in ancient blacksmithing.
Googling seems to indicate that the term "carbidize" is used almost entirely by the knife industry, or at least I can't find any other sources of the term. The descriptions of the carbidizing tool that you can buy on various knife maker sites, describes it as a process of layering the titanium with tungsten from a sacrificial tungsten rod. Sounds sort of like tig welding without the inert gas or filler rod.
http://link.springer.com/article/10.3103/S0967091209060072
I did find this scientific journal, which I'm not going to buy, but you can read the first couple pages for free. The sample pages seem to indicate that carburizing titanium results in carbidizing the titanium with a layer of graphite/carbon. So it almost sounds like carburizing titanium could be categorized as a subset of carbidizing, using high-temp carbon transfer rather than plasma arcing tungsten. Except, the seeming lack of carbidizing as a general industry term makes me question my little hierarchy. Whatever. As usual googling increases my knowledge and confusion at the same time.
Whatever the case, it seems likely that CRK's invoice line item of heat treating the lock is really re-carburizing the lock-bar face. So from the various responses on this thread, it seems like depending on what is required to "tune" the lock, CRK will merely adjust lock bar tension, re-carburize the lock face (and I suspect tweak the lock-face of the blade tang as needed), or entirely replace the lock-side scale (and tweak the lock-face of the blade tang as needed).
Haha, mystery solved?
Your last paragraph is correct, I believe. However, that triangular area is a different color because they tape it off before bead blasting to protect the detent.
