- Feb 25, 2011
Hello,
I am getting a lot better with my Apex. I am learning that there is a lot of technique to be developed, even when dealing with this seemingly foolproof tool. What's the next step after using the EP 1000 grit stone? I have been using a DMT xtra xtra fine diamond stone with edge-trailing strokes and almost no pressue, and this seems to help, but I have ordered some EP 3000 grit tapes and a leather strop block, which I plan to load with 0.5 micron green compound. Do you think I will see an improvement with these? Do you have other suggestions? Am I making too-big of jumps in grit fineness in the final steps?
Also, I am wanting to experiment with different backings for the polish strips. I have some rock maple that I plan to make blanks out of and some very thin rubber material that I thought of gluing to blanks to provide a little "give" to make a sort-of strop out of the polish strips. Do you think this will work?
If you use edge-trailing strokes, what is your max grit size for edge-trailing? I have read that 3 micron is a good place to start with edge-trailing.
Also, I have been thinking about this: what is really the point of using ANY mounting blank at all with stones? Can't you just clamp unmounted stones directly into the EP? This is what I do with my DMT stones. I don't see much utility at all to the mounting plates, unless you are using a lot of pressure to the point where a stone snapping or slipping out of the clamp might be a concern. As an extension to this line of thinking, I am considering using 1/4 inch thick stones from Congress Tools. You could just clamp unmounted 1/4 inch stones into the EP and they would be roughly the same thickness as a mounted EP stone, you would then have 2 surfaces on each stone that you could use, which would translate into less frequent need for flattening. What do you think?
If you use Congress Tool's stones, which grit progression and stone types do you recommend? How do they wear in relation to the EP stones?
Thanks!
Thanks!
