- Sep 24, 2008
I was wondering what is your favorite angle to sharpen your knives and why? I am getting a sharpmaker in a few days and was wondering what works better for an edc knife in s30v? 15 or 20 degrees? THANKS
There are two issues - application and steel hardness. If you make the angle too acute for those two things, the edge will fail under use. If you make it too obtuse, you will waste some cutting performance. The only way to get to the sweet spot is to experiment.
Here are some broad generalizations. Less then 15 degrees only works with very hard steel and applications in which you do not cut against something. Some butcher knives, as an example are very acute and stand up just fine. For a folder with hard steel - RC58 or more - 15 degrees should work just fine. For softer steels or fixed blade knives use 20 degrees and for striking knives like cleavers use 30 degrees. You can adjust from those points but you should be pretty close. For kitchen cutlery (excluding cleavers) use 15 degrees for Japanese knives and 20 for Western knives.
Thanks for the input so far. I think i''l first try 15 degrees on each side, and if i have any problems i'll bump it up to 20 degrees per side. The steel is s30v from CRK so i hope it is solid,for how my wallet looks.
And for cutting tasks, pretty much anything that would arise for EDC. I don't think i'll be cutting anything that would chip or damage the edge, but then again, who knows.
I run all of my quality steels with a 10 per side or less back bevel and microbevel between 15 and 20 degrees per side depending on how the steel holds up. The thin backbevel increases cutting ability and ease of sharpening, while the microbevel makes resharpening very fast and will give your edge the durability of the wider angle that you are sharpening at. You can also convex your edge to get the same benefits I mentioned with the thin backbevel/wider microbevel set up. From experience a 20 degree microbevel would probably benefit your CRK S30V, while something like my Spyderco Stretch 2 ZDP or my Krein Ultimate Caper in M4 can cut fine with 7 per side edges and microbevels as thin as 10 per side. The good thing about microbevels however is that as long as you redo your backbevel every several sharpenings so it doesn't thicken up using a 20 per side microbevel as opposed to say a 15 per side microbevel will have minimal effect on cutting ability while have a pretty significant effect on durability. See Sodak's post in the Microbevel thread stickied at the top of this sub forum to see pics of what a difference a microbevel made on his Queen knife's durability.
Mike
Similar here ... most blades, when I first get them, I take down to 12 deg./side, whether it's something I would EDC, or a large chopper. I generally finish sharpen with a microbevel of 17 deg./side, sometimes 20 deg., depending. If the steel is at all decent and the heat treat reasonably well done, this is plenty robust unless you're doing very abusive work, or are careless or really unskilled using a blade.I run all of my quality steels with a 10 per side or less back bevel and microbevel between 15 and 20 degrees per side depending on how the steel holds up.
