- Sep 5, 2017
I post on this thread because I want input from people are really invested in knives. Thanks everyone
I currently have a spyderco tri sharpener it puts a great edge on it I was just hoping for a mirror polish on some knives. Thanks for the input everyone.
If all you want is a mirror edge you can finish on your sharp maker and then take it to strops.I currently have a spyderco tri sharpener it puts a great edge on it I was just hoping for a mirror polish on some knives. Thanks for the input everyone.
Would the edge pro stones work well with that high vanadium steel?If all you want is a mirror edge you can finish on your sharp maker and then take it to strops.
Though I like to use a guided system and run them through a progression of stones first to make uniform scratch patterns to reduce stray scratches in the end results. It's not really necessary.
Use your diamond or cbn rods to reprofile if needed then goto medium, fine, extra fine sharp maker rods then remove the bur on a strop then use some compound on a few more strops to remove any left over scratches. Or so that's the theory.
If you have high vanadium steel I'd highly recommend diamond or cbn for sharpening tho. It's not like it can't be done with the ceramic stones... But the vanadium carbides in super steel cannot be cut with ceramics due to them being harder than the rods. So it ends up just loading the Sharpmaker rods.
It's debatable. I've seen charts that show SiC is harder than vanadium and charts that aren't. They certainly do work. But how much difference between diamond in actual cutting in vanadium, is hard to say without proper info and visuals.Would the edge pro stones work well with that high vanadium steel?
So if I got that system would I just have to get finer stones to get a mirror polishI’m happy with my WE-130 but depending on the steel, you’ll need to buy finer “stones” to get a finer finish.
It appears the “best” finish depends on the type steel you’re sharpening and the material being cut.
Mirror edges require progressively finer “stones” and strops based on my reading here. Even I have found it fairly easy to get a mirror finish with the KOWS with some lesser steels but I haven’t spent enough time and money on all the things necessary to get that finish on S110V.
