What's the best way to keep my sebenza razor sharp?
I have a small Sebenza but I know very little about sharpening...only videos I have seen on youTube. Should I get a SharpMaker? Or is it possible to keep it honed just by a regular stropping on a stropping block? I cut a bunch of cardboard with it yesterday and want to return it to razor sharpness... How do you keep your CRK (or any knife) honed to razor sharpness on a regular basis?
Thanks!
block o' wood and leather
or leather strip with some sandpaper on it
I'ts super easy and avoids errors, only takes some little practice on cheaper knives
I have a guide but it's on the Italian forum and can't link it here
I can send it via PM
maxx
search for a thread called "revelation on keeping my Sebenza sharp". Chris Reeve posts his way of sharpening and it does involve a sharpmaker, I follow his instructions and am very happy with the results.
Thanks!
By no means am I an expert in this area but I'll share my experience and limited knowledge. The first time you're "shaping" (yes, that's shape not sharp) the edge, you want to set aside an hour or more of undisturbed time. My experience has taught me it's very difficult to find and follow the factory angle so It's best to make your own. This way, you'll be able to touch up the edge super quick when it needs sharpening. And, many factory edges aren't even on both sides, the edge grind is more like a chisel than a V. However, CRK knives are often ground very even on the edge. It's the BM's that I find have more of a chisel edge.
The "secret" is to GET A BURR on your edge (temporarily). This means to cut away enough that one side folds over the other. Before I do that, I make sure I've removed an equal amount of metal from both sides so that the edge of the V sits directly in the middle. I verify this under a 10 power loop. Once that's done, work one side until the edge folds over and you feel a lip when dragging your nail backwards against it. Then cut the burred side until it just starts to do the same on the other. From that, start working finer grit stones 6-8 times a side until your final stone. Make sure each time you're finished a side, the other side DOESN'T have a burr. After the final stone cut, I use 3 different types of compounds on a leather strop. Get yourself a 4 sided block with leather attached. I have all flesh side visible on all sides of my leather strop, but some like one finished side of leather to use as the final strop. It's a matter of preference. Each sides gets a different compound and the last piece of leather is left dry. I use that to clean the blade.
I tried to simplify it the best I can but if you have questions about the process, please ask. If others have better success sharpening another way and would like to ad, that would be great...:) Even though it sounds like a lot of metal moving, it isn't. I'm moving a little metal off the sides and very little off the edge. Move as little of the edge as possible. The further the edge is pulled into the grind, the better off you are. As the edge falls back into the grind, the V angle is greater and the more pressure you'll need to apply to your cut. I get a lot out of a little. There is an argument of hollow grind vs flat grind and what cuts better. That's an entirely different conversation and best discussed elsewhere. This being said, I prefer the hollow grind of CRK because it suits my needs in a knife, and it'll take more sharpening before a back angle is required. I use to use a Sharpie marker to determine how much metal I've actual moved off the factory edge. I can assure you it was VERY little. Once you've established your own angle and edge, it takes VERY little work to touch it up. Most of the time I can do it with the last stone and a few stroke on the strop.
I will say the edges of my knives scare the hair off my arm, hold an edge and look pretty. It's like carrying a straight razor in my pocket that works like an ax when needed. In the photos below, the band of edge might appear large in the photos, but it isn't. It's not much wider than the factory, but it is even and looks beautiful. The blade on this Sebenza is S35VN. I can't say what's easier for me to sharpen, 30 or 35. If I recall, the 30 was actually harder to shape than the 35. I do know so far, the 30 holds an edge longer but will chip easier. The 35 will fold before it chips. At least that's what I've experienced to date.
View attachment 280741View attachment 280742
There are many diferent methods to use while sharpening a knife. Just remember, a knife can get "beat up" while learning to sharpen. Whichever method one chooses to learn, I recomend perfecting technique using knives that are less expensive. Learning can be frustrating, but the rewards are worth the trouble. Enjoyit as sharpening can be a hobby unto itself.
Sounds like you need a Sharpmaker. I've failed to see anyone that could not use one with ease. They did come with a DVD, just follow those instructions and you won't have a problem. A good leather strop will also help. I strop(or steel) after every use to maintain the edge without having to remove metal. If the strop doesn't do it take it to the fine, or ultra fine stones. The key is to never let it get very dull if you can help it.
Also, if you don't have a loaded strop you can use cardboard to strop with for now. It works pretty good.
Later on you can learn to use a flat stone if you want, but you need something now that you can use ease.
Also, one tip on the Sharpmaker...don't let your tip come off of the rods. It will round the tip. Stop you stroke just before the tip comes of of the rod.
Good luck.
Thanks for the comments and advice fellas. It seems that learning how to sharpen is in my future. Maxx, I'd love to see that guide!
Keeping your Sebenza sharp is very easy. Get a good strop. Stropman makes great ones. If it gets dull it will require a bit of work, or you can have CRK sharpen it for free (you pay shipping).
2 keys: (1) Listen to the people on this forum, they're smart. (2) Start with every old knife in your house and sharpen them before you tackle your seb.
I think you'll soon find that- no matter what method you use-there's a real kind of therapy that comes with it.
i either like CRK sharpen it for free (you pay shipping both ways), or send it to forum member richardj for sharpening for $6 and you pay shipping both ways.
What I use is mainly a Knives + strop and spydreco stones. Unless you do some serious cutting you should be able to just hone your blade, once you notice the edge isn't as sharp as it was give it a couple swipes on ceramic rod and then hit the strop, I have a Para2 that I carry alot and it has never been sharpened, only honed and its hair popping sharp:D When I'm camping or the like I always bring my Spyderco Doublestuff for touchups, its light and small and all you need for a good working edge. I would def recommend the Knives + strop ( thanks CS)
Thank guys. I ordered a $19 strop block from Knives plus. The green one that is already loaded. I figure I will use that to keep my knives honed on a daily basis. I am also going to commit myself to learning the art of sharpening. I am fortunate to have Tom Veff only 20 minutes away for $6 sharpening should I need an experts touch.
I like to strop with the grey solution then I go to a sharpmaker this will keep the slight convex on the blade.
If you strop don't go hard just light strokes. Presure should be like shaving, just the weight of the handle.
Do the latest Sebenza 21's still have the high hollow grind with convexed edge? Thanks
The best way to keep any knife sharp is simple... don't use it! In a real world, avoid cutting cardboard. El-cheapo boxcutters - with replaceable blades - have a function.
Stainz
Stainz
What the heck just happened? :confused: :p :D
