Yup, RIT dye works - sort of.
G10 is not very impervious, so it is hard to get the dye to penetrate. If you can remove the scales, heat up a pot of boiling water then remove from heat. With the dye mixed in, drop your scales in and let them soak for at least 15 minutes.
DISCLAIMER - don't use your wife's good pot, as the dye will stain it.![]()
the thing is I don't want to dye the whole thing, rather dye some part of it, like put a pattern on it, yeah I can try tape off some part, but is there any dye that I can just paint on the scale? like Tie-Dye Kit, would that work?
amazon sells Fabric Spray Dye, set by ironing, don't know if we paint/spray on G10, then use head gun, whether that will set the dye, just wonderingBeen trying to figure out the same thing as I had an R2-D2 pattern planned and ready to go for a white RAT2 in D2 steel, was not trying to dye the whole knife or do a color pattern. The issue is, I am not sure what kind of paint would be most resillient on, not G10, but a similar material called Nylon 6 used in the scales of Ontario knives.
I was told this may be a hard process to get to stick, but I too would like to try it.
