Oh! I'm with you and having different blade sizes. I have a Case trapper but it never seems to be something I grab. Might be the blade sizesMost of my knives are no longer made.
For 2 blade knives currently in production and readily available today, I like the Case Texas Jack and the Case Barlow.
If I'm going to carry a knife with 2 blades one has to be smaller than the other, so I don't really like the trapper or muskrat.
Everybody should try a 2 blade Barlow at some point, and the Case is a good one.
Everybody should probably also try a Trapper at some point, and the Case 54 pattern is probably the most sold trapper ever.
I really do like having a knife about 4" or bigger when possible. My Case Large Stockman CS has been with me all week. I'm hunting for a Moose or English Jack!Cannot choose just one.
My favorite dual blades, largest to smallest are:
1) Two blade slipjoint folding hunter. Though TBH, at over 5" closed, I consider it more of a belt knife (Like a Buck 110/Old Timer 6/7/OT, and similar knives are folding belt knives.) This is my most carried two blade. A western 062 has been on my belt everyday since July or Aug., 2024.
Currently made by Case (x265); Offshore Schrade, Rough Rider, and I believe, Boker Tree Brand. (Personally I don't care for the RR; two pulls on the clip point blade. To me that is ugly.)
Available on the used market by Case, Imperial-Schrade(US), Western, and many others.
2) Full size Moose (4.125 - 4.25" closed)
3) "English Jack" (2 blade same end jack knife that is a minimum 4" closed.)
4) Full Size (3.625" closed) Canoe.
5) 2 blade Barlow and Jack Knife, between 3.0625 and 3.5" closed.
Buck, (I think) currently has a 2 blade 301 double end "stockman" available, based on the 2018 "Traditional" Forum Knife.
Tere are several discontinued Buck 300 series 2 blades, that are smaller than I will carry.
5) Peanut (2 7/8" closed) Case and several others make the Peanut pattern. Case also has a "Texas Jack" that is just over 3" closed.
The "Muskrat" pattern is similar to the Moose, but is equipped with (usually) two "Turkish"/"California" clip point blades, and is around 3 7/8" closed.
The Trapper is another option. The full Size trapper is 4.125 to 4.25" closed. Smaller ones are made
I had a RR Tiny Trapper, around 3" closed. (Best I can tell, the poltergeist in the expedited box truck I drove "borrowed" it, and never returned it. (I know there was a poltergeist in that truck. A couple of the pocket knives it borrowed, I later found in the mini-feidge's freezer. I have NEVER put a knife in the freezer. Nor have I ever needed a knife to get something out of a freezer.So, no way I "accidentally" left it in there. I was asolo driver when that tiny trapper went missing, eliminating the possibility of a co-driver "borrowing" it without saying anything ... darn poltergeist ...
I agree with Jeff's statement. If I'm carrying a 2-blade traditional, I like a primary blade with some belly and a straight-edge secondary blade. Here's another example, a Case-Bose Eureka Jack. GEC made one also, I believe. They both would be harder to find and likely a bit pricey, but it's a nice pattern.I like the combination of a clip main and a straight-edged secondary.
Check out the RR "Sow Belly" mooses. The "Spey" blade has a LOT of belly.I'm hunting for a Moose
