What's the point of a recurve on a pocket/folding knife?
I totally get it if folks like recurve grinds on their knives. They do look cool on some blades. But I, myself, would never buy one. To me, they are pointless from a practicality standpoint. They are hard to sharpen, and the only advantage (that I know of) a recurve has is on a machete when you are chopping.
Just wanted to know if I am missing something. Thanks for your feedback.
If you're cutting rope or some material like that. In my experience its almost like having a bit of a hawk bill on a more practical blade.
They excel at making pull cuts. Popular pulling motion cuts for recurved blades are pruning plants, opening boxes, and removing material from wood to use as kindling.
I like them. Kershaw offers them in spades. Especially the KO designs. I love all the bump knives that have a pronounced recurve. The pull cut is what they excel in. They sharpen just fine with my edge pro. I like having multiple cutting surfaces on one blade.
Really good at cutting round hay bales open. Thats what I cut with mine 75% of the time too.
I have on that I use to strip large wire 6awg-500kcmil. One reason I started making knives was to make a knife for electricians, many company's make one but they didn't have all the features I was looking for, skinner drop point to open boxes, re-curve to strip wire, bottle opener/prying end on the butt. What I came up with is bulky and ugly that needs some rethinking.
Pointless? Have you used a recurve blade much? I was never a fan of them until after I started using a 710 regularly and I realized that recurves are awesome cutters. Sure, they can be a bit of a pain to sharpen, but they work really well for a lot of what people do with a knife. Even a very slight recurve like the one on my beloved 710 is noticeably useful.
I caught on to recurves when I bought one. It's like having a one serration blade - it keeps advancing the edge into the material, unlike a conventional blade that lets it recede; you have to keep tipping the handle up to keep the edge working into it. Most of what we cut isn't very big, so long slicing cuts that use a circular sweep aren't common.
I bought a Boker Folts Minimalist Tanto, and discovered it's an excellent cutter on the pull stroke. Another design I have seen are the drop point tanto recurves. Basically the tanto chisel point is laid down with a recurve behind it, giving you a straight edge forward section and the recurve in one blade. Essentially a dual grind, with a much finer point centered in the blade, giving superior penetration.
It results in a blade that almost looks inverted - which is actually quite common in blade patterns. Almost every one made has an inverted shape that is also used - skinner vs carpet, wharncliffe vs tanto, etc. A recurve tanto is basically a clip point upside down and reversed end to end.
Sometimes I get the feeling that the leading knifemaker designers just keep a eye out for what is the leading pattern on the market, flip it around, and then call it New! to make a name. There really is almost nothing in a knife blade that hasn't been done before, you just have to look and you will find it.
I recently got a ZT 0350 and 0301, both recurves. I was unsure about them but after having used them for some time I can tell you that the recurve really "bites" when cutting at the sweetspot in the recurve. I dont find sharpening them any more or less difficult than any other blade.
I like em!
Drew
Sharpening recurves is no harder than sharpening a straight edge.
Exactly this,
And all the other posts too.
I sharpwn all of my knives on a $10 set up of just grits from 100 to 2000(if i really want to spend time) sandpaper, and the side of my beater desk, flat stones are easy as well, just use the corners of the stone, after a lot of fails and time i learned a cube with some kind of sharpening surface is the best way for recurves, because its harder (for me) to get the tip finer on this than those ceramic or diamond rods, because u have to be more precice with a rounded surface... I probably screwed up what i was trying to say :o
My 0200 is a cardboard monster, it bites right in and rarely ever mis cuts or i loose close control
My Kershaw Blur is a recurve and I have no problem with it.
I've been impressed with the way my 0600 cuts, recurves definitely at least deserve a try.
