I've noticed something about my Sharpmaker technique that's....strange
i can get a PE knife bloody sharp (no pun intended) using the corners of the Sharpmaker hones, enough so that i can do that "slash cutting" thing you see Sal do on the video, they get shaving-sharp on the corners
but when i go to the flats, it almost seems like it's *dulling* the edge, after a session on the flats, i can't slash-cut paper, it actually hooks and drags, tearing the paper, if i run a couple passes down the corners again, i can slash cut paper again
i've watched the video a few times, and i'm working on already sharp knives, with the factory edge (specifically, my Native), and i want to maintain that edge at maximum sharpness, i keep the knife straight up and down and use slow, controlled passes with light pressure, just as specified in the video, the only way i depart from the video is i sharpen on one rod until i feel a burr forming, then i do a few passes down the opposite side to straighten out the burr/edge, i found that tends to set the edge more effectively than "20 passes per side, alternating"
are my knives too *short* for the flats, perhaps (the longest blade is the Endura 3, shortest are the Jester and Buck Metro), are the flats designed for knives with more blade area, like kitchen knives or fixed bladers like the Ka-Bar?
it doesn't seem logical that the flats should *dull* an already sharp blade....
what am i doing wrong?
