- Apr 4, 2020
hi starting out and would be grateful for advice on what hardness of wheel
I have no idea! I better ask the selleris that durometers?
Great thanks"IF" that is in durometer numbers go with the 75. I think "most" of the 12" contact wheels in use will be around the 75 durometer mark.
I think they are normally mounted on a 1/2" bolt with larger bearings. I found an ebay listing with the same description as you posted, and I don't think the one I looked at was made to accept bearings.it is 1 inch will take 1 x ⅜ bearing so I will use a ⅜ th bolt , do guys run them normally without bearings?
