I apologize if I'm mixing up terms or if I'm obviously confused. If I'm confused about the terms I use in my question, I wouldn't mind being corrected.
Here's the question: assuming I want to put in a secondary / relief bevel combined with a micro / primary bevel, when in the process and at what starting grit do I put in the micro / primary bevel?
I forget where I read the idea but I like the sentiment that the coarsest stone stage is what makes the edge sharp (fully apexed, zero burr edge) and the succeeding grits are to refine the bevel (smoothing out the surface).
Given this, after I get the edge sharp at the coarsest stone (more acute angle), do I then put in the micro bevel (relatively obtuse angle), then refine the relief bevel with the finer stone (more acute angle), then put in the micro bevel again? This seems to be Murray Carter's method in his video. At both the coarse stone and the fine stone, he works the relief bevel, then puts in the cutting angle.
Or do I work the relief angle from coarse to fine, then go back and work the cutting edge / primary bevel / micro bevel on the course then fine? This doesn't make sense to me by the way but I'm just going through the different possibilities.
Or (assuming I have more than 2 grits of stones, do I work the relief bevel through the coarse, medium, fine first, then work the micro bevel on the last and finest grit only?
Or do I start first work on the relief angle only during the coarser stones then at some intermediate grit, do I start including the micro bevel?
If it matters, I'm thinking of having relief bevels at 2 degrees more acute than the primary / micro bevel that I want. For example, 13 dps relief for a 15 dps primary / micro bevel.
Thanks for your thoughts on this matter.
