DaQo'tah Forge
Banned
- Aug 26, 2002
Hi this is DaQo'tah
okay,I know Im not going to ask this question right, and I know you may never understand the type of problem Im haveing...I have never had a belt grinding lesson, Im just learning as I go,,,but I have run into a big problem with trying to sand flat the ricasso area.
I just dont understand the order of when to do the sanding.
here is my problem.
Im working on my blade on my belt grinder,
Now at first when the blade is fresh out of the coal forge, I work the flat sides of the blade to make them nice,flat, and even. then I put a taper from infront of the guard all the way to the tip of the knife.( I just use a 36 grit belt)
then when that looks close, I start to grind the bevels.
But along the way i have to also grind on the Ricasso,,,but every time I do that, I mess up the nice bevel...
My questions is...Do I first just grind the ricasso going from 36 grit, all the way up to my last grit of 600?
or do I grind the ricasso at the same time as the rest of the blade, but do it a different way?
here is my problem.
