- Feb 4, 2011
I've read several comments saying I should always grind my knives after they have been heat treated to prevent the blade from warping, but I've seen many demonstrations where the maker grinds first, then hardens, or grinds most of the steel, hardens it, then finishes the grind.
I've also come across heat treat service providers that say things like "make sure you blade profiled and ground correctly before sending it. Anything you want to change after hardening will be nearly impossible to grind out"
Let me know what you think. What do you do personally? Are some of these methods flat out wrong?
