- Nov 29, 2005
Ok, I should be nearing the last of my questions
-Do you polish before, or after you heat treat? (Or, do you polish to some degree before, then some after?)
-And does that same thing go for a clay coated, differentially tempered blade?
-One of the first knives I'm making is a full tang grafting knife (A small knife for making clean cuts on tree limbs under a half an inch, or so.) So, it's a lot of tang, and two inches or so of blade. How deep into the one-brick forge do I push that? (The blade sits right at the fire hole when I push it in up the the tang area.)
-Is it bad to heat treat the tang?
-If I'm just supposed to push it all the way in, do I just not quench the tang?
-Lastly, would it even out the heat some in the one-brick forge, to place bits of brick (say, two pieces, 1" wide, and as tall as the brick, one on each side of the heat hole) so it makes the hole narrower?
Thanks again. Looking forward to posting pictures of my first knives when they're through
