I'm more concerned about the locking mechanism breaking or failing.Blade shouldn't close on your fingers if you are cutting normally
And most of the time you'll want to cut away from you and not towards yourself
How would that prevent cuts to my fingers if the lock fails and the blade folded?If you cut towards your body and the blade slips it could cut you. I'm sure plenty have folks have been seriously injured doing this. Therefore cut away from the body.
but what happens if the back spring/ stop pin and the pivot fails....then you're in for a world of hurting when that blade goes flying away...If you are applying pressure to the cutting edge, you are forcing the blade open, not closed.
Holds true for modern folder, a slipjoint, and even a friction folder with no lock or stop pin.
If you are applying pressure to the cutting edge and any of those fail, the edge of the knife blade will continue upwards, away from your fingers.but what happens if the back spring/ stop pin and the pivot fails....then you're in for a world of hurting when that blade goes flying away...![]()
wasn't being serious friend.If you are applying pressure to the cutting edge and any of those fail, the edge of the knife blade will continue upwards, away from your fingers.
Cutting away from your body is to prevent the knife from slipping and cutting into you. Which is fairly common. I wouldn't worry too much about lock failure, having never had it happen to me in years of using knives for every imaginable task, and having never met anyone who had a lock fail. I'm sure they do, but it's never happened to me. Knife slipping on the other hand... Let's just say slippery potatoes and dull knives aren't my favorite.When using a knife and cutting away from your body does this help prevent the blade from closing on your fingers in the case of a lock failure? I mean putting pressure on the sharpened part of the blade.
