Where can I get a Cordura style sheath for a FFBM?
privateisland
BANNED
True.
Also, Semper Paratus Tactical, one of the Busse site's makers, does a great job with cordura wrapped kydex.
www.semperparatustactical.com
Dan does great work.
Any of the other makers on the Busse site can probably hook you up very well also.
The 2007 SE is a no-go also. It's 0.270" thick just like a Dogfather but the blade is too tall. I tried it just to see if it would work, it didn't.
It's still great for the CG's.
Could you heat up the sheath like kydex? The sheath that lancelot showed is exactly what I'm looking for. Is there any mods that would make it work?
Unless something has changed, that won't work for an FFBM.
It works for the thinner FBMCG but the fatties are too thick and the blade is a hair taller, some of the liners will be too small in both dimensions.
I keep seeing this incorrect advice being repeated. The FFBM will not fit in any of the Scrap Yard sheaths that I have.
Good to know.
I think I remember hearing about someone cutting the rear of the kydex liner out of the Swamp Rat Cordura sheath that came with the Camp Tramp so that the HO FSH would fit in it. Don't know if this is a workable option for the FFBM.
The liner isn't kydex. You could buy the sheath and then try to make a kydex liner that would fit.
I haven't tried it but it might be possible.
If it is possible, it would still be a tight fit.
