Where can I get a Strider SNG tanto?
Where can I get a Strider SNG Tanto?
Between the AR, GB, and SNG(both version), which one is a better folder?
Thanks
Well, actually, you can't get one.
Not yet, anyways. I don't believe they are out yet. You can pre-order from a number of dealers. Should be available any day now.
And actually, I don't know a source that has a GB/AR in stock right now. There will be another run of ARs after they finish the current run of SnG's.
I don't think the AR/GB is any better or worse than the SnG, just different.
Good luck!
-- Rob
There not out just yet, about another week. If you really want one I highly suggest that you get on the pre-order list at www.tadgear.com and reserve yours now, otherwise you will miss out on this batch and there is no telling when another will be available. As far as which is better the AR/GB folders are a whole diffrent animal then the SNG, they are quite a bit bigger then the SNG but keep in mind that I've never met a Strider that was not double tough.
