- Jun 25, 2001
Where is the line between production and Custom hand made knives?
This tends to be a big difference of
opinion between makers.
Some makers feel if you use a miller then your getting into factory making,
Some feel as long as you control the machine by hand your hand making.
If you surface grind yourself or you buy your stock pre ground is there a difference?
I think, but don't do myself, a true hand made knife would be getting your own ore and
smelt it yourself putting in carbon as you see fit from the coke, then forge the blade using
your hand made tools and hand made files you make yourself.
Make sure you make the forge and anvil by hand also,
well you get the point, this would be great BUT if it were this way, not many custom
makers would grace the knife world.
***What do you think the line is?
I do consider my knives Custom Hand Made
Because of most the reasons you guys gave below.
I forgot to add Bench-made in between the two.
But talking to others on the subject
I thought I'd get some good views on it.. thanks.
Good thing my knives are sharper then my spelling.
...Dan..
.<A HREF="http://www.kynd.com/~graydg/kniveslist4.html">Gray Knives</A>
[This message has been edited by Graymaker (edited 06-28-2001).]
...Dan..
