This is our collection of 2-56 TORX screws with black and stainless variants. These 2-56 TORX screws have thread lengths between .125 and .500. There are also many different screw head types including flat, button, and phillips heads. These screws will work great in your next knife making...
www.knifekits.com
Ti connector has a bunch but they are are pricier if my memory is correct.
Some stainless versions in sizes like 4-40 can be found at home depot or your local hardware store. Amazon has a bunch as does the similar sites.
Generally the threat specs are 2-56, 4-40, 2.5-45. Measuring the major diameter of the thread will get you close to the spec once you look it up on a table. the first number being the nominal size the second if threads per inch.
