Make your own.
Hobby Lobby has 8"x11"x.0625" sheets of veg-tanned leather for $6 after online coupon.
HomeDepot/Lowes has Poplar and Maple finished lumber in 1x2, 1x3, 1x4 for about $2/ft.
Contact Cement is available everywhere.
So, for about $10~$12 you can make 4~6 strops of various sizes.
How to I tell if it is veg-tanned leather from the hobby lobby online store. I see tooling leather.
Thanks
That's it - Large Tooling Leather - http://www.hobbylobby.com/Crafts-&-.../Leather-Pieces/Large-Tooling-Leather/p/29470How to I tell if it is veg-tanned leather from the hobby lobby online store. I see tooling leather.
It's only 1/16" thick so there is no additional processing necessary. Just cut it to size and glue it down.
The key is stropping with the correct angle so your not rolling over the edge or only stropping the shoulders. A strop is the final step and you should have a sharp edge already so you don't need much pressure. I typically only use the weight of the blade...only time I'll use a lil more pressure is when I'm maintaining the edge after use and still it's very light pressure.Why do you believe that simply because it's only 1/16" thick that there is no additional processing necessary?
How thick does leather have to be before it's able to roll over an edge due to improper pressure, or rather, how much leather actually rolls over an edge due to improper stropping pressure?
Stitchawl
Because I have actually made and used such strops. Have you?Why do you believe that simply because it's only 1/16" thick that there is no additional processing necessary?
Anything can be produce bad results with "improper pressure".How thick does leather have to be before it's able to roll over an edge due to improper pressure, or rather, how much leather actually rolls over an edge due to improper stropping pressure?
Thanks, but I'll continue to rely on proven first-hand experience.
