A couple of years ago, on another forum, I learned a great deal about chain saws and axes for serious wood work in a more rural setting then I currently find myself in (rural farmland versus the big city).
My interest has now turned towards the tools one would use to build things in the city when remodeling a home or building furniture, patio decks, gazebos and, similar structures. Specifically, Im looking at things like table saws, compound miter saws, jig saws and, the like. Common tools like drills and circular saws are relatively easy to compare and actually find but, I have found that discerning differences in general; quality, performance and, value specifically; to be a challenge with most other tools.
To start my work shop off initially, I am leaning towards purchasing:
Items I am currently undecided on are:
In general, what should I look for in a pro-sumer grade tool? I want to buy the right tool the first time and would prefer to buy more tool then I need, then to buy not enough the first time and be forced to re-purchase the right tool the second time around.
To narrow things down a little, my current tools are pretty much all DeWalt (drill, reciprocating saw, circular saw, ¼ sheet pad sander) along with a few other stray tools from Black and Decker and Ryobi. I have been looking at Makita, Bosch, Hitachi, Milwaukee, Porter-Cable, Skil, and Delta products in general.
Specifically, the Makita LS1212 12" Dual Rail Slide Compound Saw seems to be the compound saw of choice based on what I have read on the net. I am unsure if this is way overkill or a good long term investment. Looking at the local $300 saws from DeWalt and Delta, I was a little concerned with how they would work on fine moldings and most of them required you to reverse the material to make angular cuts the other direction. Repeatability of the settings was also questionable based on what store personnel had to say. Im thinking $300 to $700 should buy a heck of a saw but, what do I know?
Table saws in general are still a large unknown. Looking at rip fences and router attachments in addition to the obvious aspects of the motor and saw blade setup, I am confused here. Descent saws seem to start at around $450 and go up from there. What should I be looking at?
Any references to good books or other forums and/or web sites would be most appreciated! And yes, I have been to Home Depot but, I am finding the tool selection and knowledge lacking (The "no Big Box store" rule seems to restrict what they stock and, the knowledge of the available help varies a lot and, they don't have much time to spend with a single customer).
Thanks for your help!
Sid
- A traditional table saw so that I can rip plywood and similar materials in various widths
A compound miter saw for cutting everything from trim moldings for window boxes to hide the Venetian blinds to angular cuts for patio deck planks and 4x4 timbers
- A high performance Jig Saw for cutting irregular shapes
A sander of some sort (other then the common ¼ sheet pad sanders) to smooth wood surfaces for furniture
A router to make my own moldings and soften furniture edges (should this be mounted/mountable in a table saw bench?)
Sid
