- Jan 3, 2011
My workshop is almost set up. I just picked up my new evenheat kiln but im not sure where to place it in the shop. I wish I had a picture to show of the shop layout. Its 8' x 8' and 9' tall. Theres not much room to move atm.
When you walk in the door there is workbench area down both walls.
Im thinking of putting the kiln next too the door it will be a tight fit im wondering if the cold air from the door will effect the hot blades ??
Also what height should the kiln be at. To save space I was going to put it under one of the work benches around waist height from the floor. Im not sure if this can heat up the shelf above it and cause a fire or not ??
Also Im starting with 1084 and 1095 and I cant seem to track down any sort of quench oil here in BC Canada.
Any help with this would be great thanks !
