My question is, can a convex edge be touched up in the field or out in the real world with whatever is at hand?
That's always been my reason to hesitate on convexing my knives. With a conventional edge, I can touch up on the bottom f a coffee mug, smooth stone from the creek, side of a brick building, or top edge of a car window. I've done all of them, and I always have a sharp knife. How much sharper will a convex blade get?
Carl.
Easily. Very much so.
The very cutting edge of a good, sharp convex is still essentially a V-bevel anyway (otherwise it'd be too thick & dull). So, they can be touched up like any other edge. Many manufacturers of convex blades usually finish them with a small V-microbevel anyway, and even recommend conventional methods for edge maintenance (stones or Sharpmaker, for example). Opinel and Fallkniven come to mind; both are convexed blades (Opinel is subtly so), but both brands recommend or even sell conventional 'stones' for maintaining them.
The real slicing advantages of a convex are in the smooth shoulders of the bevel behind the edge, which reduces binding in thicker & tougher material, but the edge itself is no different than any other. I see a certain distinct advantage in maintaining a convex, because it can be touched up using 'dedicated' convexing techniques (edge-trailing stroke), if/when it's convenient to do so, or by using the methods ordinarily used for V-bevels (edge-leading). Just that many more options.
In some respects, it could be argued that a convex is even easier to maintain than a V-bevel, by 'stropping' the edge on any slightly forgiving surface like leather, or a few layers of paper or fabric, or even on stones or hardwood, with almost any decent abrasive applied (river/stream silt, sandstone dust, etc.). This is how a lot of folks in other areas of the world do it, with dust/dirt/sand on wood. Essentially, all of convex sharpening comes down to 'stropping', albeit with varying degrees in abrasives, depending on how much work the edge needs. And whether intended or not, all freehand edges will end up with at least some slight convex in them anyway. That's an inevitable result of the variability in angle control that comes from freehand sharpening.
The ease of maintaining a convex, with very simple materials, is the main reason why it's my favorite sharpening method.
