- Feb 12, 2007
Hi, I have a Lansky sharpening system, it has set in angles of 30, 25, 20, and 17. Which angle would be best to use? The edge will only have to take on tape, paper, cardboard, and an occasional thin rope.
17
A thin blade of tough steel can take a 17, but good luck getting a 17 on a thick blade.
I don't know why people keep saying this. Buck's 'Edge 2K' was just a lower angle. I sharpen my knives between 10 to 13 degrees per side. There is no issue with edge life for normal cutting tasks.Also a 17 will lose its sharpness faster if not in an optimum match with the steel.
all you will end up with is a wider edge bevel, 17 degrees is still 17 degrees
I also use a Lansky system, and I am looking for advice on what angle to use to sharpen a Cutco Chef knife...Thanks, Roy
